Ir para o conteúdo principal
Lançado em junho de 2014, o DreamTab HD8 é um tablet Android para crianças criado pela Nabi e pela DreamWorks .
How do I fix this?
Hi. I got my Nabi Dream tab back in late 2015. It was a good tablet. I got a Fire Tablet in late 2017 and decided to put the Nabi up. Well little did I know that was the year Android 4.4 ended its support and nabi discontinued its products. So here I was the other day doing some rearranging in my apartment. I found the nabi in my closet and it is still in good condition meaning: no cracks, no dents, no scratches, no water damage, LCD is fine. It also charges fine. I left it on the adapter for a while and it got fully charged. Once it was done charging, I decided to turn it on. It was stuck on the dream tab characters for about 10 minutes. So I shut the device off and got on the computer and looked up how to do a factory reset and I got to the last step but it wouldn't factory reset it just kept saying it was "wiping data". So I tried every option on the recovery kernel. I can't disassemble it because I lost my screwdriver for that and I refuse to buy new tools. Also I have an old Chromebook so I can't do the debugging or booting or any of that. Please help me. My Plan is to turn it in to a normal tablet by getting into the parent mode.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Dear Mike W, I know the dreamtab is discontinued and i'm missing a charger and i'm not sure how do i use it but you still got some tools and i hope you can fix it and get a new charger for me because i've played a way back in 2014 and i like it and i'm gonna use it forever and thank you for using it always. From Enrique Olivan p.s. if you still like these kids' apps you are gonna buy me a innotab from vtech because i've played back in 2014 and i'm loving it and again thank you for using it always.
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
@mikew2025 take a look on here. It explains on how to convert it to an Android tablet. It's an older link which should work with your older hardware.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Will it help make my Nabi boot on normally?
por Compartilhar
@mikew2025 it'll supposedly turn it into a regular Android tablet.
por Compartilhar
Adicionar a sua resposta
Mike W será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 43
Ao todo: 1,127
