Ir para o conteúdo principal
A Máquina de Lavar Maytag modelo MVWB765FW é uma lavadora de abertura superior com opção de enchimento profundo. A lavadora tem um volume de 133 litros.
Model 765FW3MVWB won't start.
When we turn on the washer, the start button will not work. We turn the knob to try a different setting but it only lights up normal setting... we try to press a right side button to modify any of the other settings like deep clean or extra rinse but they won't light up either.
We tried lifting lid 6x in 12 sec. We tried counter clockwise then clockwise 2 clicks then counter clockwise then clockwise but still stuck on normal and won't start.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi Lori,
You're not the first person with this same exact problem on this kind of washer. Check out the answers on this question and see if any of them resolve your issue. If not, come back and let us know and we'll see what else we can try.
SOLVED: Why my washer not powering on? - Maytag Washer MVWB765W - iFixit
Esta resposta foi útil?
Pontuação 1
Hi,
Here's the tech sheet for the washer.
First check the DIAGNOSTIC LED – MAIN CONTROL (ACU) as described on p.2 and if OK try to run the diagnostics as described by the guide and check what error codes result
Pontuação 0
Adicionar a sua resposta
Lori W será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 548
