Ir para o conteúdo principal
Informações de reparo para o Xiaomi Redmi Note 8T, um smartphone lançado em novembro de 2019. Este celular possui o número de modelo M1908C3XG.
After changing display, there are problems
Well I successfully changed display to some from Chinese market one, but after changing display there are some problems now:
  1. Sometimes you have to press power button multiple times to wake up display
  2. Sometimes when someone is calling you, display won't react to touches and you can not pickup call.
What could be causing this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@playandwin from what you are describing, it sounds like a bad display/touch screen assembly. Of course, always double check your work ensuring all the cables are properly seated and the connectors are in good condition. Also try a reset so to rule out any software issue. If you ruled all that out, you know its the display assembly. Can’t repair that but would need another replacement.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Clean the motherboard with alcohol 90 degree
por Compartilhar
If you put a protection on the screen put it off
por Compartilhar
Adicionar a sua resposta
Lubik será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 20
Ao todo: 649
