Ir para o conteúdo principal
Add Door open DC3 code wf45k6500av/a2
Samsung model wf45k6500av/a2 DC3 code.
How does the machine sense if the door is closed/locked? Is there a prox switch or is it measuring psi on the latch?
Is there a specific schematic for that part? Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @onecrappieday
The service manual doesn't show a schematic for the door switch per se but it does show that there is a door lock switch LG part # DC34-00025D and also a door switch as well LG part # DC64-00828G
Imagem
(click on image)
Hopefully this may be of some help.
Imagem de Secures the door of your washer to ensure proper operation during cycles.
Produto
Samsung Washer Door Lock Switch - DC34-00025D
$124.99
Imagem de Prevents the washer from running when the door is open, ensuring safety and functionality.
Produto
DC64-00828G - Samsung Washer Door Switch
$26.99
Esta resposta foi útil?
Pontuação 1
1 comentário:
Outstanding @jayeff ! The service manual is what I needed. We'll check the motor and switch today.
por
Adicionar a sua resposta
Mike Jones será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 62
Ao todo: 1,198
