Caiu na água e não liga mais
Esta é uma boa pergunta?
@jugomes For now, stop using your phone. Do not try to turn it on or to charge it. That can make things worse.
The very first step I would take is to disassemble your phone. Use something like this video to work on your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair.
After the cleaning and after you replace the battery, use the Samsung Flowchart to check further.
I hope this makes sense to you. If not, ask and I will try to clarify.
Translation
Por enquanto, pare de usar seu telefone. Não tente ligá-lo ou carregá-lo. Isso pode piorar as coisas.
O primeiro passo que eu tomaria é desmontar seu telefone. Use algo como este vídeo para trabalhar em seu telefone. Observe atentamente todos os componentes e conectores. Avalie verdadeiramente o dano. Procure por grande corrosão, avalie os pinos nos conectores etc. Dê uma olhada em todos os conectores, bem como nas extremidades dos cabos. Você terá que remover todos os escudos EMI. Se você não remover as blindagens, não estará limpando a placa. Depois de limpar a contaminação grosseira, use álcool isopropílico 90% + e limpe suas peças um pouco mais. Para uma limpeza adequada, use este guia. Ele foi escrito para um Apple iPhone 3G, mas ainda é pertinente ao seu telefone. Eu não posso enfatizar a importância de uma boa limpeza o suficiente, então faça isso várias vezes enquanto substitui o álcool após cada limpeza. Não use ar comprimido para a limpeza, pois isso pode conduzir líquidos e partículas de corrosão em áreas que causarão problemas mais tarde. Não use água potável, se precisar usar água, use água estéril. Além disso, você não precisa deixá-lo secar por um dia. O álcool isopropílico na concentração mais alta evaporará rapidamente e dissipará a água. A importância aqui é a limpeza. É claro que seria melhor limpá-lo profissionalmente. Não se esqueça de substituir a bateria. Esta é uma obrigação e não uma opção. Vai falhar se você não cuidar disso agora. Depois disso, remonte seu telefone e reavalie. Enquanto você não limpar sua placa e substituir a bateria, tudo é apenas um palpite. Tenha em mente que os danos causados pela água são os mais difíceis de solucionar e reparar.
Após a limpeza e depois de substituir a bateria, use o Samsung Flowchart para verificar melhor.
Eu espero que isso faça sentido para você. Se não, pergunte e tentarei esclarecer.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 53
