Ir para o conteúdo principal
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
just using one inlet hose connected to my machine
I am using just one hose connected to my machine bc I have just cold water if this affect the function of the machine?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Guillermina Ortiz what make and model is your washer? NO, it should not interfere unless you set your water temp to anything but cold. If nothing else, you can always get a Y adapter to connect the one hose to both inlets on your washer. Something like this would work.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Guillermina Ortiz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 148
