Ir para o conteúdo principal
O Lenovo IdeaPad 3/3i 15ITL6 é uma variante de 15 polegadas do IdeaPad 3, baseado na plataforma Intel de 11ª geração. Existem vários modelos diferentes com diversas configurações de CPU, RAM e SSD, no entanto, o reparo de todos eles parece ser basicamente o mesmo. Lançado em 2020.
C and D case broken
My lenovo NB IP 3 15ITL6 back case and keyboard case broken, u have any support
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
Here's the hardware maintenance manual, taken from this support webpage for the laptop.
It will help you to disassemble the laptop so that the parts can be replaced.
Here's a link to the parts for the laptop.
Click on Select Commodity > C-cover with keyboard (504) to find all the part numbers for the available covers for the model range. The covers are country specific as can be seen by the country code in the title of each keyboard. You may have to search a bit to find yours. Usually the part number can be found somewhere on the underside of the cover if you wish to verify that you have found the correct one, but you have to remove it first of course ;-)
By "back case" do you mean the lid? If so, click on Select Commodity > LCD parts (9) to find the part numbers for the LCD cover. The LCD cover is colour specific as can be seen in the part title. Again usually the part number will be somewhere on the underside of the cover for verification purposes.
When you have the required part numbers, search online using the part number only to find suppliers that suit you best.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
S AF será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 651
