Ir para o conteúdo principal
The Asus Zenfone 5 Lite (ZC600KL) is a smartphone manufactured by Asus, first released in February 2018.
1 Perguntas Visualizar todos
My phone keeps turning on and off after getting a little wet
so i was at the stadium and it was raining hard, my phone were in my pocket for a couple of minute until i put it in my bag because i realize it could water damage my phone. and yes, it was a little wet. when i was using it after it's still running like normal, but when i get home and about to fall asleep, my phone suddenly turns off even though its still on 60%, i've tried to charge it but when i do that it keeps showing me a no battery logo while turning on and off, when i tried to turn it on it keeps showing me an asus logo and turning back off, please help me solve this
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to a teardown video that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
qintharaagadri será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 90
