Ir para o conteúdo principal
O Xiaomi Redmi Note 9 é um smartphone intermediário da Xiaomi lançado em abril de 2020. Ele possui um display LCD IPS de 6,53", uma câmera principal de 48 MP, um sensor de impressão digital montado na traseira, uma bateria de 5020 mAh e é executado com um MediaTek Helio G85.
Device reboot continously when in Standby-mode
Good Morning,
i have the phone of my mother in law and it's rebooting continously when in standby. as long as the display is on, you can use the phone normal, but after locking it device starts to reboot again and again. did someone have this before?
btw: Chargng is a little bit slow, but i think it's because of the reboots (more power needed).
Esta é uma boa pergunta?
Pontuação 1
3 comentários
Have you tried to update software or firmware? It could maybe be a Internal Issue but im not sure what would cause it.
por
this is impossible, because when i tried it it fall back to bootloop at 64% Updated.
por
non of the above works i have tried power and volume+ button but it is not going on that
por
Adicionar um comentário
3 respostas
Pergunta mais útil
@m0ddmylife
What happens if you start the phone in safe mode?
If still no good, here's a link to the schematics which may help as it has Level 1, 2 & 3 repair instructions.
I haven't tried this link but have used the website before for other makes and models and they were OK.
Esta resposta foi útil?
Pontuação 1
Your smartphone might experience a reboot loop if its cache memory is full. To test for that possibility, you should empty your phone's cache
Regards,
Will
Pontuação 0
1 comentário:
I've set it back to Factory mode multiple times, so this is not working.
por
i have a had the issue a couple times what i do to fix this is, is to hold the power button until the lock screen appears
Pontuação 0
Adicionar a sua resposta
Michael Kastner será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 34
Ao todo: 1,456
