Ir para o conteúdo principal
need help with know which board is the inverter board
which board is the inverter board on the Vizio E55-E2 s/n # LWZ2VIKT4505529 i need to replace it but every time I google it I get the power board
edit note: so I basically did the test with the flash light and results say it’s the inverter board and didn’t see anything with the light strips is that hard to replace ?
New pictures more notes
The only test I did was the flash light test. The tv image went super dark after a min of being on and the image would only come back after the tv was turned off for a while but the image would go back to dark after a few min. Anyways, when it did go dark I would flash the light at it and could see the image better
Esta é uma boa pergunta?
Pontuação 1
6 comentários
Michael Rey post one picture of all the boards and all the interconnect cables. Essentially what you look at when you remove the back cover.
por
Gotcha !! I got a few more
por
@Michael Rey thanks for the images. Yes, your “inverter” is part of the mainboard.
por
@oldturkey03 so the main board is the power board, the brown board ? Also would you recommend switch bothering with the light strips ?
por
Also THANK YOU SO MUCH! @oldturkey03
por
Exibir mais 1 comentário
Adicionar um comentário
2 respostas
Pergunta mais útil
Michael Rey your TV may not have a inverter board. The inverter circuitry is most likely part of the power board. Remove the back cover from your TV and post some good pictures of the board layout and the interconnect cables. That way we can verify and hopefully guide you further. Sounds like you are having backlight issues. Remember, Vizio has issues with bad backlight strips.
Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 3
2 comentários:
Hi,
To add to the answer, looking at the images you posted, the power board has a connector (CN202?) which has 8 outputs all with +18V and 8 with gnd.
I dare say that these wires are the backlight power feeds.
If the wires go through the chassis to the screen then most probably they are.
If to another board on the back then they're not.
With the TV turned on, use a DMM and measure the voltage on pins 1-8 with reference to an earth, e.g. a screw head.
If there is no voltage then most likely it the power board, or perhaps the mainboard telling the power board not to turn this voltage on. I don't know how Vizios works in regard to the backlight power whether it's controlled by the mainboard or not.
If you measure +18V and the backlights aren't on it's the strips although it would be unusual for all of them to fail at once.
por
The LWZ2VIKT has the LED driver on the mainboard. Last picture is yours. Its the LWZ2VIBS, LWZ2VICS or LWZ2VIDS that use a separate board
por
Any screen I've worked on the inverter is in the screen surround connected to the backlight. If you find it be careful you don't get a shock
Pontuação 0
Adicionar a sua resposta
Michael Rey será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 743
