Ir para o conteúdo principal
O Asus ROG G752V é um laptop gamer de 42,8 x 33,4 x 5,3 cm e 4,36 kg, fabricado em 2016.
Screen replacement for model G752VY
I am trying to find the replacement screen for this laptop, do you know by chance which model is it?
Thank you in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @chester_cheetah ,
There are two LCD panels available for the laptop.
An FHD (1920 x 1080) display which has a 30 pin video cable connector (Asus part # 18010-17330500) and a UHD (3840 x 2160) display which has a 40 pin video cable connector (Asus part # 18010-17320800).
Search online using the part number only, applicable to your particular variant, to find suppliers that suit you best. If you don't know what type you have already, you may have to open the laptop and check what size video cable connector is on the motherboard.
Usually the part number is located on the back of the LCD panel somewhere if you wish to verify before ordering.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Felix Garcia será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 15
Ao todo: 487
