conserto do xiaomi redmi note 7 e resolusao do problema
o que fazer se meu aparelho celular entou em contato com a agua
Esta é uma boa pergunta?
@jhon001 for now you want to stop trying to use your phone, to charge it or even to turn it on. That could make a bad situation worse.
The very first step I would take is to disassemble your phone. Use these guides Xiaomi Redmi Note 7 and video like this to help you disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can't stress the importance of a good cleaning enough. Do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned After that, reassemble your phone and re-evaluate. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair.
Translation
@jhon001 por agora quer parar de tentar usar o seu telefone, para o carregar ou mesmo para o ligar. Isso poderia agravar uma situação má.
O primeiro passo que eu daria é desmontar o seu telefone. Utilize estes guias Xiaomi Redmi Note 7 e vídeo como este para o ajudar a desmontar o seu telefone. Observe com cuidado e atenção todos os componentes e conectores. Avalie verdadeiramente os danos. Procure corrosão importante, avalie os pinos nos conectores, etc. Dê uma vista de olhos a todos os conectores, bem como às extremidades dos cabos. Terá de remover todos os escudos de EMI. Se não remover os escudos, não está a limpar a placa. Uma vez limpa a contaminação grosseira, use mais de 90% de álcool isopropílico e limpe mais um pouco as suas peças. Para uma limpeza adequada, use [guia|5825|estes-guia.] Foi escrito para um Apple iPhone 3G mas ainda é pertinente para o seu telefone também. Não posso sublinhar a importância de uma boa limpeza. Faça-o repetidamente enquanto substitui o álcool após cada limpeza. Não utilize ar comprimido para a limpeza, uma vez que isso pode conduzir o líquido bem como partículas de corrosão para áreas que mais tarde causarão problemas. Não utilize água potável, se precisar de utilizar água, utilize água esterilizada. Além disso, não é necessário deixá-la a secar durante um dia. O álcool isopropílico na concentração mais elevada evaporará rapidamente e dissipará a água. A importância aqui é a limpeza. Depois disso, remonte o seu telefone e reavalie-o. Não se esqueça de substituir a bateria. Isto é uma obrigação e não uma opção. Falhará se não se ocupar dela agora. Enquanto não tiver limpado a sua placa e substituído a bateria, tudo é apenas um palpite. Tenha em mente que os danos causados pela água são os mais difíceis de resolver e de reparar.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 279
