Ir para o conteúdo principal
Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
Is it possible to just replace the SSD, to a 1TB or 2TB NVMe SSD?
I have a similar question. I'm worried that my fusion drive may eventually have issues on the rotating media HD. Is it possible to just replace the SSD, to a large (1TB or 2TB) NVMe SSD with a pin adapter and reformat the existing HD to be used as a JBOD partition? In other words, can the PCIe SSD act as a stand alone drive instead of the original Fusion configuration?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
The original post was a 2012 system which has two SATA ports. It doesn't offer a PCIe/NVMe port or a way to add it. Replace fusion drive with a single SSD
If you have a 2014 system you have the ability to install a custom Apple or OWC PCIe/NVMe drive.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Douglas Lee será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 334
