Ir para o conteúdo principal
Informações de reparo e desmontagem do smartphone Android topo de linha S21 Ultra da Samsung, lançado em janeiro de 2021. Também conhecido como Samsung SM-G998U1
Loses Cell Signal After Screen replacement
So I am testing the phone return repair the signal is working fine fore me have Data and can watch youtube videos. Checked swim card status and my Signal Strength is -107 dBm 33 asu is that bad or good Idk how to read that. Says 4G LTE
Should I reseat antenna connections or is it something else or is it working and my customer just has bad reception where they live?
Esta é uma boa pergunta?
Pontuação 4
1 comentário
Is there any workaround this? I made the, now in hindsight, mistake, of purchasing a refurbished S21 Ultra from Amazon Refurbished that has dead signal most of the time when indoors. I reckon they replaced the screen as part of the refurbishment process without knowing they needed to swap the original antenna in. Unfortunately, sending back the device was not an option at the time so I couldn't get a refund.
por Compartilhar
Adicionar um comentário
4 respostas
Solução escolhida
Signal and service issues on the S21 series are typically related to an antenna issue. Even if your new part came with the antenna in the top right corner, you need to transfer the antenna from the original screen and frame. Not sure why, but they seem to be paired together and not transferring the original will typically result in degraded service or no service at all.
Update (08/23/2022)
Sorry image wouldn't post as a comment above:
Imagem
Esta resposta foi útil?
Pontuação 7
5 comentários:
I did transfer it over but your saying if I replace the part it still will have issues because I was gonna replace the parts just because I don't see the error happening but the customer instead of not doing anything and disappointing my customer
por Compartilhar
Apologies, I missed that you transferred the antenna from the original frame to the new one. We ran into the same thing a while back and transferring this antenna from the original fixed it: [image|2721646]
With the original antenna transferred and no damage to the board, they might just be in a bad service area.
por Compartilhar
Is there a fix for this ? I just got done spending 433$ to have my phone repaired and its practically useless. Thank you! (it is too late to get my original antenna back)
Although now the shop is claiming that they did use original antenna because new part doesn't come with one.
por Compartilhar
i had signal issue with s21 ultra, after transfering this antenna it worked just fine.
por Compartilhar
Hi, I am trying to open antenna of my samsung device but none of the available tools are helping. could you recommend me something that can help opening it easily. Thanks
por Compartilhar
Its very easy to solve this problem, i was also facing the issue but currently i have solved it.
Reset your network settings and your problem will be solved
https://okadtech.com/samsung-s21-signal-...
You can refer to this article, this will help you in resetting your network setting.
Go and solve your problem and thanks me later.
Pontuação 1
3 comentários:
Following this guide did not fix my issue, I transferred both antennas from the previous frame but mobile data refuses to work unless I'm standing pretty much right next to a cell tower if I buy new antennas would that fix my issue?
por Compartilhar
Replaced the antenna but after 2 days i had no signal even when i put in a different working motherboard.Yoyr advise on going to genral management resetting network di the trick now my data and network perfect,thank you.
por Compartilhar
Yes,the problem happen becouse up trangle gsm, GPS antanna couses weak signal, calling in prograss
por Compartilhar
I'm having a similar problem with a Samsung S21U after a screen replacement but mine is having wifi issues primarily on 5G, it is working but significantly reduced range and speeds.
Repair shop said they can't replace the wifi antenna without replacing the cellular antennas also and that would require calibration the shop wasn't equipped to do. I suspect they lied but they aren't going to fix this so now it's on me.
A network connection settings reset did not help. Are there any other options?
Pontuação 0
Hello!
I have a similar issue : since de screen replacement I can send and receive text, use the 5g Lte but I can't receive or make a call it works randomly. And I can't have the original antenna back.
There is really no way to fix this but having the original antenna back?
Pontuação 0
4 comentários:
p1of3 : mine is S21 FE 5G NR, purchased from south-america, i used in USA, it had dual physical sim support. Screen began to have vertical lines when there were high-humidity & i was charging it, after i went to asian country, where 5G not yet available, phone status bar showed its using 4G & 4G+ ( aka LTE, LTE-A, etc) . i had to replace screen from one shop there, technician claimed he transferred 5G antennas etc from original to new frame, but 5G antennas were not visible from backside in new frame !! the "Phone Info" radio config page also showed 5G/NR is None etc. But phone still worked same/well as before, with “5G Preferred” mode. I usually need to use in-call speaker a lot, after few months, IN-CALL SPEAKER component in bottom side original sub-board began to malfunction !! another technician obtained suitable sub-board & setup it, & put phone in “LTE Preferred” mode. Phone lost voice call in/out functions, but SMS worked, & data speed became very very slow. I reset Wireless/Tower radio network ...
por Compartilhar
p2of3 : ... settings ... it did not function as before. i put back in “5G Preferred”... still did not function as before. i went back to the shop, this time the in-call speaker+mic component was obtained from an slightly older “One Plus” phone, that was put into s21 fe original sub-board, technician removed new sub-board from phone, put back original sub-board. after these ... again did wireless network settings reset, put in “5G Preferred” mode ... voice-call in/out still did not, SMS worked, and data worked fine with LTE & LTE-A mode. Messaging app, such as, WhatsApp, it’s usage allowed to test in-call speaker+mic component functionality. Next day i called SIM service provider, she said to keep in “5G Preferred” mode, keep SIM in primary slot, but turn off VoLTE, 2G, & reboot phone, Then again enable VoLTE & 2G, & reboot again. She also notified me they have re-sent network settings into phone & enabled VoLTE service for the SIM. And after 2nd reboot, Voice call in/out began to work & VoLTE had super ...
por Compartilhar
p3of3 : ... voice clarity. in status bar, a finger swipe from center to below shows Vo))LTE tiny icon. i also enabled Roaming (above the VoLTE & 2G), because in some areas, without it sim service did not work. Before 2nd shop technician glue in the back cover, i attached 3 thin passive antennas on the backside of phone, near the antennas, but avoiding the wireless-charging coil position. and for that, data speed is now nearly double in phone.
por Compartilhar
Can you better describe the three passive antennas and the steps for attachment ?
por Compartilhar
Adicionar a sua resposta
Mark D Schlossman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 58
Últimos 30 dias: 254
Ao todo: 25,868
