Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
Wet iPhone
I made my iPhone wet and i didn't know what to do and i used a dryer and i couldn't turn my iPhone off because screen didn't work. It looks alright apart from screen doesn't react to my finger or anything. I made it wet 5 days ago please help
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
4 respostas
Pergunta mais útil
Simon.
If you can, shut your phone off (somehow, maybe let the battery drain?) and let it dry in a bag of rice. I would also recommend trying this next time instead of a dryer. A phone alone in a dryer obviously would get beat up, but a phone with clothes or other linens is likely to collect static that could hurt the internals. Let the phone sit for a day or two to be 100% sure that all moisture is out of it. Try turning it back on and see if the screen works. If it doesn't, you may need a new display assembly which can be purchased here. We have our manual for this procedure here and I also recommend that you read our water damage page here. Hope this helps good luck!
Esta resposta foi útil?
Pontuação 1
May I recommend a Thirsty Bag? It might be of some use.
Pontuação 0
Any questions https://handyrepairgremheim.com/contact/
Pontuação 0
As far as I know… this is the place to get answers, right?!?
Or is this an advertisement platform?
Pontuação 0
Adicionar a sua resposta
Simon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 34
Ao todo: 2,535
