Ir para o conteúdo principal
Reparo e informações do dispositivo para a televisão LED Vizio série D de 50", com número de modelo D50n-E1.
Why is my remote not working?
I own a Vizio 50 inch model V 505-G9, purchased at Sam's Club in July 2020. Vizio sent me a new remote but the tv will not respond. The only way I can turn on the tv is manually at the back. Remote not functional.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Edward Reinert since this is a new factory remote we can rule it out (hopefully) and I am sure it is not a user error. New battery and all I assume. The only thing then is the IR sensor on your TV. Make sure it is not obstructed and make sure that the plastic cover in front of it is clean. If all that checks out it is possible that you will need a new IR board. We would need to know your exact model number and you will have to remove the back cover tec. for that. Of course, check to see if it is still under warranty etc. If so let them fix it to their cost, not yours.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Edward Reinert será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 293
