Ir para o conteúdo principal
Repair guides and troubleshooting information for hair dryers.
28 Perguntas Visualizar todos
Why the air from my hairdryer is smelling very bad
The air is smelling very bad
Esta é uma boa pergunta?
Pontuação 0
5 comentários
Hi,
What is the make and model number of the hair dryer?
Does it have a "burning" smell?
por
Check the back of the hairdryer. Sometimes there’s like a mesh that gets clogged up restricting the flow of air through it, if it doesn’t get enough air flow it will start to overheat.
por
Does you hairdryer have a screen for filtering out debris going into the unit? Did you check for hair getting past it, entering the heating element and cooking hair? Cooked/burned hair usually results from the unit ingesting hair and creating the terrible smell.
por
@notbroken you’ve just wrote what I said 😂
por
@strongbow, blocking or restricting airflow tends to allow the heating element to create hotter air temps without burning but any debris like hair getting into a hair drier will burn and melt creating the bad odors.
por
Adicionar um comentário
1 resposta
Solução escolhida
Try cleaning the filter maybe?
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Rukhsana Begum será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 56
Duração total: 453
