Ir para o conteúdo principal
Repair guides and troubleshooting information for hair dryers.
Why the air from my hairdryer is smelling very bad
The air is smelling very bad
Esta é uma boa pergunta?
Pontuação 0
5 comentários
Hi,
What is the make and model number of the hair dryer?
Does it have a "burning" smell?
por
Check the back of the hairdryer. Sometimes there’s like a mesh that gets clogged up restricting the flow of air through it, if it doesn’t get enough air flow it will start to overheat.
por
Does you hairdryer have a screen for filtering out debris going into the unit? Did you check for hair getting past it, entering the heating element and cooking hair? Cooked/burned hair usually results from the unit ingesting hair and creating the terrible smell.
por
@notbroken you’ve just wrote what I said 😂
por
@strongbow, blocking or restricting airflow tends to allow the heating element to create hotter air temps without burning but any debris like hair getting into a hair drier will burn and melt creating the bad odors.
por
Adicionar um comentário
1 resposta
Solução escolhida
Try cleaning the filter maybe?
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Rukhsana Begum será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 802
