Ir para o conteúdo principal
O Nissan Altima é um automóvel de porte médio fabricado pela Nissan, podendo ser considerado uma continuação da linha Nissan Bluebird, iniciada em 1957.
How do I replace the instrument cluster lights.
I have been trying to replace my instrument cluster lights. I have watched many videos and looked all over trying to find out how for my specific vehicle. I can remove the cluster but then the circuit board has one light bulb on it that indicates the head lights. Please help.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi,
What is the specific Altima model and year of your vehicle?
Have you checked for small smd LEDs on the board?
por
Adicionar um comentário
2 respostas
normally the bulbs are very small and they are socketed.
If you have the cluster out, you should be able to drill down, removing the PCBs till you can see and remove/replace the bulbs.
Esta resposta foi útil?
Pontuação 0
I just ran into this issue as well I tore the entire unit apart on my 2006 nissan altima s with 2.5l to find out the lights are non serviceable led bulbs soldered to the cluster board.
Pontuação 0
Adicionar a sua resposta
John Lemon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 911
