Ir para o conteúdo principal
The Nissan Murano is a front-engine, five-door mid-size crossover manufactured and marketed by Nissan since May 2002 as a 2003 model and now in its third generation.
Information display screen above radio replacement
How do you I replace the radio display screen in my 2012 Nissan Murano sl without navigation and has the Bose stereo system? If possible to give a step by step explanation on how to remove the dash etc to remove the screen and replace it with the identical display replacement!?! Thanks in advance
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @c44perkins
Here's the instrument panel section from the 2012 Nissan Murano service repair manual that may help.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Cameron Perkins será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 22
Ao todo: 1,014
