Ir para o conteúdo principal
Launched in October 2014, identified by model number CHDHA-301.
20 Perguntas Visualizar todos
Replacement battery’s and back door replacement
Hi
Does anyone know where I can get a replacement battery and (waterproof)back door for the gopro hero
I also live in the uk so I need parts that can be sent to uk and cost £
It would be greatly appreciated if someone could help me with this
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @hellomacos
Search online for PR-062334 battery to find suppliers that suit you best. (see part number on original battery at 57 seconds and 1:40 minutes on replacement battery into this video)
Couldn't find a waterproof backdoor for the Hero 1 only this which is probably not what you want.
Esta resposta foi útil?
Pontuação 2
4 comentários:
@jayeff
Thanks soo much
Il have a good look at the links:-)
por
Hi @jayeff
I have had a look for a backdoor and I can’t find one for this model
Do you know if the back doors from other models are compatible
por
Hi @hellomacos
Not sure.
When looking for the part I noticed other parts were for Hero 1 & 2 but couldn't find one for a Hero 2 either ;-(
por
@jayeff
Thanks for trying
Il contact gopro directly and ask them:-)
Il also accept your answer
Thanks again:-)
por
Adicionar a sua resposta
HelloMacOS será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 138
