Ir para o conteúdo principal
O Dodge Journey é um SUV crossover de porte médio fabricado e comercializado pela marca Dodge da FCA desde o ano-modelo 2009, com uma leve reestilização para o ano-modelo 2011.
Backup camera not working all the time.
My backup camera keeps going out and coming back on sometimes it even shows the picture upside down. How do I fix it.
Esta é uma boa pergunta?
Pontuação 4
2 comentários
Mine is doing that too. Flickering and the upside down.
por
The camera is reversed
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Hi,
I don't know why the image would be upside down, but here's an image the wiring diagram for the rear camera for the 2009-2015 Dodge Journey that may help.
When the camera is not working, turn the ignition on and shift the vehicle into reverse and check if the backup lights work and also check if 12V DC is appearing on pin 6 of the backup camera. If the voltage is there check if there is an earth on pin 5.
If there is voltage and earth you will have to check the continuity of the 3 wires going from the camera to the C3 plug of the radio.
If everything appears to be OK it may be in the camera or the radio, unfortunately I cannot find schematics for either.
Imagem
(click on image to enlarge)
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 2
Its in the wiring harness at tailgate. They frey and break from the repeated opening and closing of it. Top left of it when open you'll see the boot that covers wires. Open it and examin wire. Mine were frayed and three were broke.
Pontuação 2
I know chrysler products can be known for electrical issues. I would start with checking the connections from the camera to the head unit.
Pontuação 1
Adicionar a sua resposta
Mark Reynolds será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 104
Ao todo: 16,810
