Ir para o conteúdo principal
Lava-louças integrável - aço inoxidável, 45 cm de largura Lava-louças
does not heat water
washes with cold water only.it does not heat water
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi,
Please confirm the model number of the dishwasher.
It seems as though the heater may be the problem and if your dishwasher model is not a Bosch SRI45T45EU-18 anyone answering your question may link the incorrect part suitable for your model.
Moderator
por Compartilhar
Adicionar um comentário
2 respostas
Open it. Look for the heater and measure its resistance. For a 230V Type ist should be near 24 Ohm, for a 120V Type around 10 Ohm. And: there is a pressure switch that ensures that the heater only works when there is enough pressure.
Esta resposta foi útil?
Pontuação 0
Hi - I was able to repair the Bosch dishwasher with this exact problem. It is an issue of the relay as described in this video:
https://www.youtube.com/watch?v=Jb8gAnMb...
You need to get an NTE R46-5D12-6 relay and replace it. Less than $5 part.
Pontuação 0
Adicionar a sua resposta
ahmadmomani será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 561
