Ir para o conteúdo principal
Informações de reparo para a Creality Ender 3 Pro--uma versão aprimorada da impressora 3D Ender 3, feita pela Creality. Lançada em setembro de 2018. Número do modelo: Ender 3 Pro.
3D printer blue screen
Built printer, then it turned on. Leveled the plate to the print Nozzle with a piece of paper. I printed 2 test models then a 5 hour model. All 3 models we fine. Then turned off printer. The next day I turned the printer on and only got a Blue screen.
Esta é uma boa pergunta?
Pontuação 4
10 comentários:
was the printer bumped at all?
por Compartilhar
No.
I did a puzzle tube print which took 5 hrs, when it was done I turned the printer off. The next day when it turned it on it had the blue screen.
por Compartilhar
ok, check the connections maybe. there is one on the back of the LCD and another inside the CPU
por Compartilhar
Are you using octoprint or an SD card to print your models? Try using octoprint instead on an SD card, I accidently inserted the wrong SD card and it corrupted the firmware. Try re-flashing the firmware , that usually did the trick the few times it happened to me. On one occasion the LCD connector was loose. good luck.
por Compartilhar
I checked all the connections before hand and then went through a lot of different things that others have said to do., nothing helped.
I just don't know what else it could be. It is brand NEW. I just got it and did 1 print job, turned it off after it was finished, next morning turn it on and got the blue screen.
por Compartilhar
Exibir mais 5 comentários
Adicionar um comentário
1 resposta
its 1 of 3 things u have a loose LCD or not connected properly it could be that u have attempted to mess with the power management by accident and now it's has too much/&or to little voltage and is ether broken or not working properly, or 3 it's something on the board that's needs replacing these are the most common things i run into
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Frank Lovash será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 30
Ao todo: 4,263
