Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
1500 Perguntas Visualizar todos
iPhone 3GS Coil problem
Hello,
i have problem with my iphone 3Gs.
I tried to replace the coil but when i wanted to remove the old coil the old solder pad (connector on the mainboard) was also removed.
So the problem is that i dont have only one point to solder the coil.
Is there any other solution to let the backlight work?
I found that but maybe there any other solutions:
http://s1.directupload.net/images/111222...
Please help me to find a solution.
Thanks
Update
Thanks for your information. Here a picture of it:
http://imageshack.us/f/560/cimg0661z.jpg...
Now it is easier for you to help me
Esta é uma boa pergunta?
Pontuação -1
3 comentários
Have you got a photo of your damaged part on the board?
por
This is why I dread replacing the 6R8 coil so much, too easy to damage the logicbord(expensive!) I refuse to do this EXCEPT on iPhones given to me so if it fails, I can keep it for parts
por
Fuad, if you want to send it to me to take a look at, I can. No charge unless it is fixed.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
If there is even a hint of trace left, you can dig up the fiberboard and get a better connection to it. You could do that jumper trick, but it is a bit difficult to do if you don't have experience with this type of thing.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Fuad será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 2,429
