iPhone 3GS Coil problem
Hello,
i have problem with my iphone 3Gs.
I tried to replace the coil but when i wanted to remove the old coil the old solder pad (connector on the mainboard) was also removed.
So the problem is that i dont have only one point to solder the coil.
Is there any other solution to let the backlight work?
I found that but maybe there any other solutions:
http://s1.directupload.net/images/111222...
Please help me to find a solution.
Thanks
Update
Thanks for your information. Here a picture of it:
http://imageshack.us/f/560/cimg0661z.jpg...
Now it is easier for you to help me
Esta é uma boa pergunta?
3 comentários
Have you got a photo of your damaged part on the board?
por pollytintop
This is why I dread replacing the 6R8 coil so much, too easy to damage the logicbord(expensive!) I refuse to do this EXCEPT on iPhones given to me so if it fails, I can keep it for parts
por Nick
Fuad, if you want to send it to me to take a look at, I can. No charge unless it is fixed.
por hectordtruong
