I need to replace the lighting cable will the iPhone 13 pros work
In search of a lighting cable port for the pro max but all you seel is the one for the pro is that compatible with the pro max
Esta é uma boa pergunta?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 128
6 comentários
are you in the states or europe
por daniel
@tech_ni in the states
por Andre Glass-Johnson
@Andre Glass-Johnson sorry thought it was a port you needed, should be the same cable
por daniel
@tech_ni it is the port my apologies the entire charging port on the pro max is acting up if i can use the one they sell for the peo itd be great
@Andre Glass-Johnson sorry but it wouldnt work, mobilesentrix have the pro max ports. here is a link to the pro max parts. go for 1 labelled pull so that you dont have issues. https://www.mobilesentrix.com/replacemen...
por daniel
Exibir mais 1 comentário
