Touch not working fully
If i touch the screen it does not work but software is working
Esta é uma boa pergunta?
Yash Sharma it appears as if you are referring to a Fire-Boltt Ninja Pro Max Smartwatch. If your touch screen does not work, it is possible that you will need a new display.
Esta resposta foi útil?
New display rate
@shanu p what does that mean?
It's easy to fix it if the watch is working but screen is black so you have to take hot air gun if you not have u also can take hair dryer and fully hot towards the smart watch screen afte some minutes you take some thin object and trying to put screen out after you opened screen there is a kind of wire you have to put wire and connect to the point.
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 96
Ao todo: 5,765
33 comentários
Yash Sharma this is a little cryptic. What device? What software works? What is it doing?
por oldturkey03 Compartilhar
Screen off no touch work
por Saymon Singha Compartilhar
my power or open button does not work
por Aman Syed Compartilhar
My screen is broken plzz fix it
=== Update (10/02/2022) ===
por Saeem Fajandar Compartilhar
Not touch my smart watch
por Anup Hamal Compartilhar
Exibir mais 28 comentários
