Ir para o conteúdo principal
Lançado em maio de 2020, o MacBook Pro de 13" possui processadores quad-core Intel Core i5 e i7 de 8ª geração e placa de vídeo integrada Intel Iris Plus 645. (Modelo A2289/EMC3456 com duas portas Thunderbolt 3)
No Backlight following screen replacement
Had to replace screen due to damage. New screen comes on but there is no backlight (I can see logo etc. using a flashlight). I have confirmed its not a screen issue by swapping in a known good screen to confirm.
Trying to find info on location of fuses, backlight circuitry etc. for this model (A2289) but coming up dry.
Any help locating info would be much appreciated.
Thermal scan hotter area:
Imagem
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Thank you all for the replies... I did a microscopic examination (literally) of the connectors and cables and all seems fine. Regardless I did a full isopropyl cleaning as well.
Situation is unchanged - screen on, no backlight.
I checked the fuse F8400 and its got continuity so not blown - however checking voltage across it when laptop powered on gave 0 volts.
From what little I know, this is fed as per the schematic from PBBUS_G3H - that I believe to be the main power rail. I'm just not familiar with how to trace that back further.
If anyone as a suggestion I would welcome it.... I do have access to a good thermal camera and from the few videos I've seen I thing I can look for hot components that may give a clue - not quite sure though.
por
@ Paul Jackson so you are saying you have 0volt on your fuse? Did you check for any other voltages in the backlight circuitry? You checked that attached link about what turns the backlight on etc.?
por
Sorry for the delay... yes, I get continuity across the fuse but zero voltage when machine is on. I did follow the link and as far as I can understand there is minimal/zero voltage until another circuit senses the requirement and sends through the 32V.
Without the BoardView info for this type of thing, I'm not clear on were to check for additional voltages to chase back to the source. I did put the IR camera on it on only hotter spot that stood out aside from the expected was in this area highlighted in original post.
I do have access to another machine of exactly the same model so maybe I can trace back from that one and compare - but if you have any pointers I would welcome them :-)
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Paul Jackson besides the excellent answer given by @hellomacos consider this just an addendum, The backlight fuse is reference designator F8400 and it is a 3A 32V fuse in a 0603 package
Imagem
Imagem
For some really helpful information about how the boost circuit on this model is driven etc. check on here
Esta resposta foi útil?
Pontuação 5
Hi
Iv had this happen to me with screens and it caught me by surprise!
It’s probably not a issue with the device it self as like you said the old screen didn’t have this issue
So here’s what I would check!
Check that the connector doesn’t have any black or burned pins on the connector as this can cause the issue
CAREFULLY check the ribbon cables for any debris or exposed copper or tears and this can cause no backlight
Finally I would try cleaning the connectors on both the screen and the device while it’s off with a high percentage of isopropyl alcohol as this can remove microscopic dirt that our human eyes can see!
If none of these work don’t loose hope and shoot us another message and we will try some other stuff!
Hopefully this helps though
Pontuação 2
Adicionar a sua resposta
Paul Jackson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 61
Ao todo: 1,747
