Ir para o conteúdo principal
Lançado em maio de 2020, o MacBook Pro de 13" apresenta processadores quad-core Intel Core i5 e i7 de 10ª geração e placa de vídeo integrada Intel Iris Plus. (Modelo A2251/EMC3348 com quatro portas Thunderbolt 3)
open board view not working as expected
hi
I was looking a a board view in openboard views and went to flip the board to see the other side but it just disappeared
do some schematics just do this or am I doing something wrong because I was using the flip board from within a menu
it will be greatly appreciated if someone can point me in the right direction
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
@hellomacos when you close your openboard viewer and then restart and open the same boardview, does it display it again? I am having the same challenges on some .BDV files and it is the viewer program. The image is still there just not centered on the display but it is all the way "North". It's off the screen :-) to the top
Esta resposta foi útil?
Pontuação 1
2 comentários:
Hi @oldturkey03
Just tried looking up north as you said and I worked at treat
Thanks soo much this is a total life saver!
por
@hellomacos glad it helped :-)
por
Adicionar a sua resposta
HelloMacOS será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 762
