Paper feed picks up second sheet before finishing the first
Why does my 1200 series laserjet start to feed the second sheet before the first has been completed thus jamming the system
Esta é uma boa pergunta?
David Lambert "The ECU controls paper motion in the printer by continuously monitoring the various paper sensors and coordinating the timing with the other print processes. For a detailed explanation of paper movement and the interaction of the photosensors and solenoid with the paper movement process, see “Printer paper-feed system” on page 67.
Motor
The motor is controlled by the ECU. The motor provides all of the printer paper movement.
Printer laser/scanner drive
The ECU sends signals to the laser/scanner assembly to modulate the laser diode “on” and “off” and to drive the laser/scanner motor"
So it could be the ECU. Use the SM LJ1200 for a deep dive
Esta resposta foi útil?
There are pickup roller and separation pad. You can remove both from printer -those are replaceable parts. There are 2 latches or whatever they call them - for roller to get free and you can use flat screwdriver to release separation pad. I would suggest - to clean or replace both (they should be cheap) and that could solve your problem. Also that could be metal piece that sticks to solenoid, when engages and not releasing after cycle of one sheet. Take cover off and check how solenoid is working. Good luck!
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 17
Duração total: 184
