Why do they not charge
My G533 headset won't charge or turn on no lights come on either I've tried different charging cable and PC and still doesn't work the battery is fine just the charging port I think help
Esta é uma boa pergunta?
Harvey walker, if you are certain that your cables are good and that the chargers are working, it could most likely be your charging port. Use something like this Fone de ouvido Logitech G533 não funciona sem o cabo USB to get to teh PCB. Check the charging ports soldering connection and the wiring. If that looks alright you want to use a multimeter and see if you get power etrc. on the broadside of the connector. If not then consider replacing it or resolder. Post some good pictures of your work with your QUESTION so that we can see what you see. BTW tell us how you know that the battery is okay.
Esta resposta foi útil?
Try cleaning the port using some kind of brush! (E.G: Toothbrush)
Últimas 24 horas: 5
Últimos 7 dias: 16
Últimos 30 dias: 50
Ao todo: 5,120
