Ir para o conteúdo principal
Logitech G533 Headphones doesnt work without USB cable
O que você precisa
    • If the power button lits up only if the USB cable is plugged in. You probably have a loosened power cable inside the left earcup.
    Pergunte ao FixBot
    Comentar
    • If your headphones still have a warranty, just return them to the shop.
    Pergunte ao FixBot
    Comentar
    • Before you start disassembling try all the guides on the official website to make sure your problem is not software-based.
    Pergunte ao FixBot
    Comentar
  1. Logitech G533 Headphones  doesnt work without USB cable: passo 4, imagem 1 %32
    • Take out the left earcup padding. Turn the right side of the earcup counterclockwise and unplug the battery.
    Pergunte ao FixBot
    Comentar
  2. Logitech G533 Headphones  doesnt work without USB cable: passo 5, imagem 1 %32
    • Unscrew 4 screws with Torx Security TR8 bit.
    Pergunte ao FixBot
    Comentar
  3. Logitech G533 Headphones  doesnt work without USB cable: passo 6, imagem 1 %32
    • Carefully move aside the speaker. There are very thin wires connected to it and the printed circuit.
    • Unscrew the 5 screws marked on the picture with Philips 0 bit.
    Pergunte ao FixBot
    Comentar
  4. Logitech G533 Headphones  doesnt work without USB cable: passo 7, imagem 1 %32
    • Loosen the screw on the picture and slide up the black top under it.
    Pergunte ao FixBot
    Comentar
  5. Logitech G533 Headphones  doesnt work without USB cable: passo 8, imagem 1 %32
    • Take out the middle frame piece.
    • You will need to push the speaker through the frame and take out the mic off the frame.
    Pergunte ao FixBot
    Comentar
  6. Logitech G533 Headphones  doesnt work without USB cable: passo 9, imagem 1 %32
    • Here you can see that the red power cable is loosened.
    Pergunte ao FixBot
    Comentar
  7. Logitech G533 Headphones  doesnt work without USB cable: passo 10, imagem 1 %32
    • It looks like the cables are not soldered to the printed circuit. Just glued to it.
    • Scrap off the glue. I used a scalpel.
    Pergunte ao FixBot
    Comentar
  8. Logitech G533 Headphones  doesnt work without USB cable: passo 11, imagem 1 %32
    • You can plug back the battery and hold the cable in its original place.
    • Switch the power button and the power light should turn on.
    • The light will turn on after 2 seconds. You will need to keep the cable in place the whole time.
    Pergunte ao FixBot
    Comentar
  9. Logitech G533 Headphones  doesnt work without USB cable: passo 12, imagem 1 %32
    • Now you have two options. You can glue the cable back in and risk it will get loosen again. Or solder it.
    • The weld on the picture was so crappy that the cable get off when I was assembling it back. And have to redo it.
    Pergunte ao FixBot
    Comentar
  10. Logitech G533 Headphones  doesnt work without USB cable: passo 13, imagem 1 %32
    • When I was assembling the headphones I noticed that the mic cable get partially naked. It happened because every time you move the mic leg the cable has contact with the insides of the earcup.
    • I recommend putting electrical tape over it or don't move the mic leg at all. Just use the mute button on the back of the left earcup.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Kobda
Membro desde: 01/14/21
437 Reputação
Autoria de 1 guia
9Comentários do guia
Hi, its possible to disassembly the mic to change the cable? Mine its cut in the middle and I need to replace
Sauron666 - Responder Compartilhar
Can you please link a picture of the problem? It will be easier for me to assess the problem.
Kobda - Responder Compartilhar
I have just taken apart the headphone because I have a similar problem, but I could not access the cable inside the microphone 'arm' without doing something that I thought might break it... Judging from the build quality inside I also think that it would be a pain in the a** to replace and fix it.
Miguel - Responder Compartilhar
yep, my mic cable also broke, didnt even try to fix it and rather bought external mic.
Amazing guide, I was able to fix my headset to work with batteries again. Can't believe Logitech decided to glue the cables...
Daniel Barelli - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 55
Ao todo: 7,990
