Ir para o conteúdo principal
Guias de reparo para o smartphone Android Huawei Mate 20 Lite, lançado em setembro de 2018. Números de modelo SNE-AL00, SNE-LX1, SNE-LX2, SNE-LX3, INE-LX2.
Display only working for a fraction of a second
Hi,
I just replaced the display for my Huawei mate 20 lite, however, upon reboot the screen appears to not work properly. When I turn the phone on, the android logo and text display correctly, and whenever I turn the display on it also works for a fraction of a second. Then the display only shows vertical lines. I have attached a couple of videos to show the problem. Does anyone know if I installed the display wrong or the software prevents swapping displays or maybe the several drops damaged something?
Thanks!
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@ftagliaca this looks like a bad screen since it does display properly for that split second. Contact the seller and get it exchanged. Of course you did double check your work to ensure everything is properly connected.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Alright, thanks I'll try changing it. Yeah, I checked about five times to make sure everything was connected properly!
por
Adicionar a sua resposta
Filippo Tagliacarne será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 345
