Ir para o conteúdo principal
Screen done ppartially dark
Imagem
Imagem
Imagem
Imagem
I have a Samsung ua75ju6400
Turned it in yesterday and 3/4 of the screen is dark. When I put it against a white background it’s green
I have done a pic test see images
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Screen completely black when TV is on you will hear only sounds no pictures
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
carina.dimaranan at first look it appears as if that this a backlight issue but the green color etc. would be very odd for the backlight. This actually looks more like a panel issue. You could try and take a look at the boards. Remove the back cover from your TV. The main board is the one where all the video inputs connect to. See if you can make out anything that looks odd, like charred or even missing components. Of course, you can also post some good pictures of all of the boards with your QUESTION. That way we can see what you see. Adding images to an existing question - iFixit Repair Guide
Esta resposta foi útil?
Pontuação 1
2 comentários:
do you know if the panel is replaceable?
When you say panel do you mean the lcd film?
por Compartilhar
@carina.dimaranan those are not readily replaceable. Hard to come by and when you can find them most often they are more expensive than a new TV. It's the LCD assembly so basically your complete screen. Take a look at the boards for now and focus on the main board.
por Compartilhar
Adicionar a sua resposta
carina.dimaranan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 33
Ao todo: 790
