Ir para o conteúdo principal
Repair guides and support for a wide range of kitchenware.
Clean the limescale on the kettle
We have a disc electric kettle at work, we use it for more than a year, there was a scale on the disc, it became unpleasant to drink tea. Just rinse and rinse does not help, what can you clean? I would be glad to hear your suggestions!
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Fill pot to minimum level, add a teaspoon of cream of tartar. Stir contents or swirl the pot a couple of time to mix the powder with the water. Boil water until it shuts off. Pour out contents. Rinse pot several times.
por
Adicionar um comentário
3 respostas
Solução escolhida
Buy some citric acid power and put a table spoon to the kettle with water. Boil the kettle and most of the calcium should break off and dissolve. After the kettle has cooled rinse with water and wipe clean. If it has not removed all the limescale just repeat. Citric acid is food safe and natural.
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
Run vinegar through it (boil it) a time or three this will remove the mineral deposits repeat until you see its all good. The vinegar is acidic and especially heated eats the basic lime away.
Pontuação 5
6 comentários:
Agreed. Vinegar makes an excellent calcium/lime deposit remover. OP make sure you let the vinegar sit on the scale build-up so that it has time to work!
por
Brandon is right you can heat it before end of day then leave it soak overnight (off, for safety)
por
You could even use some lemon juice or something as well
por
Anything mildly acidic,. Yes. Coke for example LOL.
por
This also works on shower heads and so on. As Brandon pionted out soaking helps so does agitation. Heat speeds up chemical reactions. A bit of scrubbing once softened helps too.
por
Exibir mais 1 comentário
baking soda and boil it 2 times and then do it the 3rd time with plain hot water then tip it out and put fresh water in it and its ready to use again.do that every 3rd week
Pontuação 1
1 comentário:
Baking soda is wonderful stuff for removing/controlling odors, will cut grease quite well and lots of other things but its a base, not an acid so this will work to control odors, yes.
por
Adicionar a sua resposta
Lia Hughes será eternamente grato(a).
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 40
Últimos 30 dias: 134
Ao todo: 1,754
