Ir para o conteúdo principal
O Xbox Elite Wireless Controller Series 2 foi lançado em 4 de novembro de 2019 e é compatível com os consoles Xbox One, X e S, além de PCs com Windows 10/11. Modelo 1797.
Left stick drift and delayed response time
The left stick is always drifting. Sometimes it's not noticeable in game but in menu it will cycle up consistently. Sometimes a quick flick fixes it. Other issue is you press the stick in and the action is not always crisp, there is a delay
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta mais útil
connect the controller to a pc or laptop then open this site, https://gamepad-tester.com/. it will show you how bad its moving. if bad it needs the analogue stick replaced.
Esta resposta foi útil?
Pontuação 2
Hey Tyrone! I was able to fix it by opening up my controller and cleaning the sensors on the left stick. This helped me a ton.
When you get to step 11, make sure you move both the green plastic housing for the left stick's sensors. The one on the right controls the X axis and the one on the bottom controls the Y axis. You most likely need to clean out the bottom sensor with some canned air and it should work.
Saved me a few hundred bucks by not buying another controller! Hope this helps out!
Correção de drift da alavanca analógica no controle Xbox One Elite Series 2
Pontuação 1
i replaced the analog stick but the problem persisted. i think it might have something to do with a capacitor
Pontuação 0
Adicionar a sua resposta
Tyrone Palmer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 40
Ao todo: 4,479
