Ir para o conteúdo principal
Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
387 Perguntas Visualizar todos
Why does my console take super long to load games?
One day after I decided to play on my console I noticed that it was taking a very long time to start and when I tried playing it took WAY longer for games to load than it used to. It’s gotten to a point where navigating the console settings has become super tedious as well because of how long everything takes to load.
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Hey there! I feel your frustration with your console taking forever to load games. Not fun at all.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Good afternoon,
As you may know storage drives will perform slower when they are full (Or close to). Although this rule holds up, if it takes longer than 5 seconds to move between menu items then something is really wrong here.
Often times hard drives can spit out warning when they are really old (Rolling on my g'ol friends at ltt).
Lets try this: Bring your ear close to the PS4 at these 3 stages
  • Startup: When you turn on the PS4 if it is louder than the disc drive that would mean it's time for a new one
  • Idle: When it's just sitting on the home screen is it obnoxiously loud? This is another sign that it needs replacement
  • Loading the game in question (Please let me know ASAP): When loading up that game (And all the others) Is the hard drive spinning at really high RPM's? I wouldn't say that's hard drive replacement level.
  • It is also a good idea to check if the fans are really loud at these three stages. This means it's overheating and thereby throttling. If this is the case then either: Replace the thermal paste or diagnose it to a component around the board.
Apart from that I don't really know as I am not a technician on PS4's. Someone who would be better fit to solve this would be @jayeff or @danj. I'll leave this with them as they are a lot more experienced at this.
Esta resposta foi útil?
Pontuação 2
1 comentário:
@np_f1_2021 - I'm not a gamer so I have no knowledge on how to approach this issue. True drives slow down when you have too little free continuous space more so in HDD's with SSD's Wear Leveling kicks in which slows you down and is often a sign the drive is about to fail soon if you don't clean things up in either case.
por
Hello this is Maxed Out IT
SO check the reset the ps4 just put it in safe mode and reset it that is what fixes it most of the time of that doesn't work then it might be the HDD IF that is the case go to this website a lot of fixes are on it those might fix it wish you luck
https://www.ps4storage.com/ps4-is-slow/
Pontuação -1
Adicionar a sua resposta
Gregory Garcia será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 25
Últimos 30 dias: 82
Duração total: 1,034
