Ir para o conteúdo principal
Encontre reparos e informações adicionais para a geladeira Samsung RF28HFEDB, um modelo com freezer inferior, porta francesa, design embutido e máquina de gelo automática. Esta página abrange informações para números de modelo que correspondem ao padrão RF28HFEDB**.
Ice Maker Not Working
We purchased a second hand Samsung refrigerator RF28HFEDBSR/AA Everything was working at the time of purchase. We moved it let it sit for a week then installed it. The water dispenser works fine but it is not producing ice.
Esta é uma boa pergunta?
Pontuação 0
12 comentários
What model of refrigerator
por Compartilhar
Samsung RF28HFEDBSR/AA
por Compartilhar
@wiccapheonix - Can you take a video of the inside and outside while its trying?
por Compartilhar
I could but theres nothing to show, it doesn't do anything. No sound at all
por Compartilhar
@wiccapheonix - A video would be kind of helpful,
Make sure its not blocked try running a small amount on water though
por Compartilhar
Exibir mais 7 comentários
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @wiccapheonix
I can't find a service manual for your model but here's the start of the ice maker troubleshooting flowcharts that may help.
It is for a RF28H series so hopefully it may be close enough to be of some help.
If you can't hear the ice water inlet valve when the ice maker test switch is operated, check the wiring connection to the valve (location is shown in the link - this IS for your model). It looks like there are 3 valves, so it will be a main supply, dispenser supply and ice maker supply. To get water to flow the main has to be operated as well as the desired individual valve i.e. for dispenser it is main and dispenser valves, for ice maker it is main and ice valves. As the dispenser is working obviously the main is as well. So you need to work out which one is the ice water valve
If it seems OK then on p.50 it shows how to remove the ice maker so that you can check if there is water in the tray or not.
Also on p.60 it shows how to get into the diagnostic tests mode which may help.
Sorry I can't help further and especially if the manual isn't relevant to your model
Imagem de Supplies water to your refrigerator's ice maker and water dispenser.
Produto
DA62-04027A - Samsung Water Inlet Valve
$158.99
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thanks!!! I will give this a go!!!
por Compartilhar
@jayeff - Well said!
por Compartilhar
Adicionar a sua resposta
wiccapheonix será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 1,410
