Ir para o conteúdo principal
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
washer stopped/rubber smell what is it
on permanent press cycle halfway between 4 and rinse, small load.
what could be the problem. it seemed to attempt to start again, but only ran about 5 seconds. 22 year old kenmore
Update (03/30/2022)
this is about where the washer stopped. i tried to run it in a different cycle, but moved it back
Esta é uma boa pergunta?
Pontuação 0
4 comentários
Hi,
What is the make and model number of the combo unit?
Could be a problem with the belt or the pulley perhaps
por
i pulled off the front panel, i can't see anything...maybe water pump? i'm disabled and not sure i have the hand strength to get the clamps off...and I am in an apartment at 10pm so I can't make much noise at the moment. model 417.98702891. i'm giving it more time to cool down right now.
por
the basket seems to move too easy
por
It's most likely this coupling, between motor and water pump.
https://www.amazon.com/285753A-Coupler-C...
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
Here’s a link that shows where the drive belt is for the washer.
It also has a video that shows how to replace it if it is faulty.
If it is broken search online using the manufacturer’s part number only i.e. 134511600 to find suppliers that suit you best.
Imagem de Transfers rotational power from the motor to the drum in your Electrolux washing machine.
Produto
Electrolux Washer Drive V-Belt - 134511600
$33.99
Esta resposta foi útil?
Pontuação 1
5 comentários:
the washer belt is in tact from what I can see
por
ok, i banged my head on it (by accident, maybe it helped?) moved the belt/pulley manual, rotated the dial....and it's some how working. i really don't think it was of balance because there were only a few light items in it....i'll have to experiment more tomorrow
por
Hi,
Hopefully is is not the washer timer that is the problem.
was the smell more electrical burning smell than a rubber burning smell perhaps?
You should be able to start the timer from anywhere on the dial and it should progress from there.
Unfortunately if the timer is faulty, it cannot be repaired as there are no separately available internal parts for it. it comes a s a complete assembly
por
the smell was coming from the bottom, not the top were the dial is. ....not electrical at all(I know that smell from the night my parents fridge caught on fire from a power surge and then my house got hit my lightening right outside the room I was sitting in!)....just rubber, not really burning, just smelled like rubber.....the timer on the regular setting went a few years ago....i think you were the one that talked me through that....I've just been using the other settings....easy fix for that!
por
@simplymyself21
The only thing that's likely at the bottom is a worn snubber ring perhaps. Does the machine shake a lot when operating?
Here's a video that may help.
I linked this on the assumption that the part # for the snubber ring being a Frigidaire part (5308002385) even though your model is a Kenmore it will hopefully be the same procedure (rebadged Frigidaire perhaps or made to order for Kenmore by Frigidaire - all the parts are by Frigidaire)
por
Adicionar a sua resposta
simplymyself21 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 69
