Ir para o conteúdo principal
O smartphone Android Samsung Galaxy Core Prime Duos é uma variante da linha Samsung Galaxy Core Prime. Número do modelo SM-G360H/DS (SM-G360H/Dual-Sim). Lançado em novembro de 2014.
How to repair ghost touch
the phone screen touches by its self
Esta é uma boa pergunta?
Pontuação 5
3 comentários
This phone is not for working on touch
por
@chiranjitdas
See the suggestions shown below in the Most Helpful Answer
por
My mobile phone screen is damage and he doesn't work and keys can't work
por
Adicionar um comentário
2 respostas
Pergunta mais útil
So there’s actually a few things that can be causing this issue with your device.
  • The primary suspect could be an issue with the phone’s software. Make sure that the device is up to date. If anything else a forced reset of the device can help the issue.
  • The second suspect issue could be overheating or extreme cold. Definitely see if the issue continues if the phone is in a neutral environment.
  • If your phone is using a screen protector, definitely try removing the protector and see if the issue continues.
If all else fails, then it may be a defect in the screen that could be causing the issue. This would mean that the a replacement screen would be needed.
Esta resposta foi útil?
Pontuação 1
Makee sure monkey testing suit is turned off
Pontuação 0
Adicionar a sua resposta
Tonny Mike será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 1,030
