Ir para o conteúdo principal
O Sony GTK-XB5 é um sistema de áudio doméstico de alta potência com Bluetooth, lançado em 2016. Este sistema de áudio está disponível nas cores preta, vermelha e azul.
How to fix my power jack
Imagem
Imagem
Imagem
Imagem
I have tried to solder it back together but I am not sure if I have done it right can solder arc between it self as there is a small gap in the solder I did manage to turn it back on for a few seconds then it died then when I tried again there was a spark from the power jack
Esta é uma boa pergunta?
Pontuação 1
3 comentários
@andrewlang00 post some pictures of the jack and teh repair etc. with your question. Let's see if there was a solder bridge or similar that may have caused this. Adicionar imagens a uma pergunta já existente
por
@oldturkey03 added photos also I am very aware my soldering job is terrible hopefully the pictures help tho
por
It was fixed to the board better when I first tested it but taking it in and out has loosened the solder
por
Adicionar um comentário
1 resposta
Solução escolhida
It looks like these are "cold" solder joints, which means the connection between the pad and the pins are not good, which would explain the sparking. Try to touch your soldering iron to the pin and the pad and the same time to heat up both and then apply solder so it covers the pin and the pad for a flawless connection.
Imagem
Imagem
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Andrew Lang será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 27
Ao todo: 330
