Ir para o conteúdo principal
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
20 Perguntas Visualizar todos
Is my gameboy advance is not chargeing but turn on
my gameboy sp is not chargeing it not saying it chargeing in any outlit it power and work but not charge is the charge port broken or the charger is
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Oscar Kniepkamp yes it could be your charger or it could be the charging port. Start off by replacing the battery. Your device is getting up there is age and the battery would be the first thing to replace. After that you can check the charger with a voltmeter. If that works out okay you know that your issue will be either the charging port, battery connector or the motherboard. Nintendo Game Boy Advance SP Battery Replacement
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Oscar Kniepkamp será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 5
Ao todo: 100
