Ir para o conteúdo principal
O Amazon Echo Spot é um produto Echo semiesférico com tela, lançado em setembro de 2017 como parte da linha de alto-falantes inteligentes Echo da Amazon.
echo message to reboot router issue
does echo spot use 2.5 or 5.2 wireless connection. it keeps telling me to reboot my router cause it look like that is why it can’t connect. well reboot does not stop the ech from repeating the alert
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @zippychippy ,
According to this review it can use either.
Can you connect to the router OK e.g. enter router password request but just not connect to the internet?
Esta resposta foi útil?
Pontuação 1
2 comentários:
The spot want me to reboot the router but all my IOT's and Alexas and dots work fine before and after router is rebooted. The spot just can't find it or wifI to connect. Continues to tell me I must have a router issue so reboot it.
por
@zippychippy
Can you detect the spot's wifi name using a phone etc to see if it is actually on?
Have you checked your router's security protocol settings e.g WEP, WPA, WPA2 etc, just in case it is set to something the spot doesn't like? Check what your other devices that can connect successfully are set for.
por
Adicionar a sua resposta
Michael Dennstedt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 29
Ao todo: 477
