Ir para o conteúdo principal
O rádio-relógio Sony ICF-C1T foi fabricado para que, em caso de queda de energia, você tenha a tranquilidade de que o dispositivo continuará funcionando para nunca perder um compromisso.
ICF-C1 Clock runs fast
Hi everyone - my ICF-C1 clock radio runs fast, gaining about 1 minute and 20 seconds every month. I cannot locate a schematic for this clock radio, so I am unsure if I can modify an RC/crystal circuit to adjust the timing or whether this uses the 60hz mains frequency as a reference. Has anyone had any luck in locating a schematic diagram or in replacing a resistor or capacitor to have more accurate time? Technician with 30 years experience here, just looking for a diagram or helpful advice.
Thanks,
Rick
Esta é uma boa pergunta?
Pontuação 1
2 comentários
same problem. mine is about 1:30 per month. pretty close. there is nothing in sony support that acknowledges or addresses this.
por
So no luck in finding a circuit diagram for this clock radio. The clock chip is a LC87BB08A-5CD7 but I cannot find any pinouts for this chip. Does anyone know a good location to view, or does anyone have a datasheet for this chip? None of the other Sony service manuals I looked through, that actually have a schematic and a parts list, use this chip.
Thanks!
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Hi @ricketts223 ,
Don’t know if this is helpful, but here’s a link to the service manual that whilst in itself is not helpful, there are links at the bottom of the page to the service manuals for other ICF C1xx models.
A quick glance through a few of them, shows no mention of a crystal oscillator module in the parts list, so it may be that the mains frequency is used for the time reference. Hopefully yours is the same
Note: You can view the manuals online but you need to select the next page at the bottom of the page to move through the manual. To download you have you sign up to the website.
Esta resposta foi útil?
Pontuação 2
6 comentários:
Thanks Jayeff - I'll check it out. I popped the lid and there are 2 crystals, one near the radio and one near the clock chip, but unsure exactly at the moment. Just an initial cursory look. I'll definitely check out the link - thanks!
por
Did you solve this? I have a SONY Dream machine ICF-C414 that also runs fast (but I have another, bit older ICFC180 and that one doesnt drift at all even after a year+.) Would like to know if replacement of crystal or as you said a resistor or something would fix it. I dont need atomic clock here, but reducing it to drifting a minute in more than a year would be a big improvement.
por
Andrei, sorry, didn't see this until now. I never did solve the issue, sadly. I ended up giving the clock radio away and swore to never buy another Sony again
por
@ricketts223 I actually did fix it via some very tiny capacitors. Took some calibrating but now it loses about 10 seconds a year instead of original 1 second per day.
por
Very nice Andrei - thanks! Can you list what caps you changed and what values?
por
Exibir mais 1 comentário
You can't really fix this - I have the same clock and the problem is that Sony was too cheap to use a proper IC that tracks the time via the AC mains frequency (which power companies go to great pains to ensure averages exactly 50 or 60Hz over time). Here Sony is using a generic 8-bit microcontroller and running the clock off the base time-of-day counter w/out an RTC and w/ the lithium battery as a backup power source.
You can find the datasheet for this by searching the sister part number LC87FBG08A (with a different footprint), for example the datasheet is available via Mouser: https://www.mouser.com/ProductDetail/ons...
There is an onboard crystal oscillator (part S3X1, X2 on the PCB schematic) supplying the 32.768K oscillations. The best accuracy that can theoretically be achieved is ±20ppm at room temperature (~10.34 minutes gained or lost/year), but with the temperature swings on the board it's going to be worse than that.
An option which I haven't tried is to replace the XTAL with a DS3232 TCXO. Someone else figured out that you can add the TCXO instead, though your results may vary.
Sony's entire circuit is an exercise in cost savings and I cannot recommend using any Sony ICF-XXX clock to accurately keep time.
Pontuação 2
1 comentário:
Thanks Mahmoud - sad to see a company such as Sony stoop to such sad design practices. I have an old low grade cassette/8 track stereo from 1980 with a built in digital clock that keeps perfect time - even to this day.
por
I replaced the 32,768Hz crystal in my ICF-C1 clock with a 2ppm TCXO Dallas/Analog DS32KHZ chip. This part operates "stand-alone" whereas the DS3232 mentioned above is intended to be initialized by a microcontroller.
A write-up of the procedure to replace the crystal is here: https://rdzioba.blogspot.com/2025/01/son...
Pontuação 1
1 comentário:
That's great RAnalog - hope it keeps better time!
por
Adicionar a sua resposta
Rick Fecho será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 125
Ao todo: 4,744
