Ir para o conteúdo principal
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
My Kenmore stackable will agitate and wash but not spin.
My Kenmore stackable will agitate and wash but not spin. It also stops advancing the timer. If I let it go it will finish but it takes several hours and the water is gone but the clothes are soaked.
Update (02/17/2022)
Model 41799680210
Esta é uma boa pergunta?
Pontuação 0
2 comentários
My washer agitates, rinses, drains and does not shut off unless you open the lid with the timer in off position. It will not spin at all.
por
@robertbergman
What is the model number of your washer?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @profkenmore ,
Check if the idler pulley is OK and is exerting enough tension on the drive belt. Also check if the drive belt is OK i.e. no cracks, splits etc.
The supplier link above is only to show where the part is located and how much it may cost. If it is the problem there are other suppliers online that may suit you better. Just search for 131862900 to get results. (Note: your Kenmore combo unit is either a rebadged Frigidaire unit or a made to order unit for Sears by Frigidaire, not sure which, that’s why the part will appear as a Frigidaire/Electrolux part in the search results).
Bit confused when you say “It also stops advancing the timer. If I let it go it will finish…..”. Does the timer start up again or what happens to make it finish the complete wash/rinse/spin cycle and not continue doing whatever where it’s stopped at? Does it stop in the spin section of the washing cycle, with no spinning action?
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Professor Kenmore será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 542
