Ir para o conteúdo principal
7,2 megapixels, zoom óptico de 3x, tela LCD de 2,5 polegadas, lançado em agosto de 2006
Camera Shows "Lens Error"
The camera powers on, and briefly shows an image on the LCD display. Then eventually it gives a "Lens Error" message.
Has anybody gotten this error before? Know how to fix it, I'm thinking that since the camera shows an image on the LCD, it may be a software rather than hardware problem.
Esta é uma boa pergunta?
Pontuação -1
3 comentários
what error no. does it give?
por Compartilhar
pollytintop, I think it's one of those cameras that just says "Lens Error". Usual cause is sand grid and grime in the rings, a dislodged lens, or faulty lens motor. :-)
por Compartilhar
Any way to fix it?
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
If the lens does not extend/retract properly, then you most likely have something stuck in the zoom gears. If the lens extends but you hear a high pitched buzzing noise, it is the focus motor that is the gears are out or your have debris it it. I would start by reading these tips and see what you get. Also take a quick look at this video to see what you might be up against :-) hope this helps, good luck
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Danny Arenales será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 37
Ao todo: 13,696
