Ir para o conteúdo principal
Mop a vapor 7 em 1 Black+Decker FSMH1321.
Steam Cleaner overheated motor
Hi,
Is there anybody that could help me with this problem.
I’ve been using the cleaner for over 2 years now, and when i plug it on the cleaner does nothing.
So i screwed the cleaner open and immediately felt that the motor was overheated.
Would the best idea be, to replace the motor? or is there a different source for this problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
@captncook since it does not work at all and your motor get’s hot it sounds like some windings on the motor that have burned out. It is probably best to replace it or find a place that can rewind it.
Esta resposta foi útil?
Pontuação 0
Imagem
Disassemble the car vacuum cleaner
Pontuação 0
Adicionar a sua resposta
Dennis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 33
Ao todo: 560
