Spacebar cracked, how do I replace?
Was trying to remove the spacebar to clean and it cracked. Where do I get a new one and how do I replace it properly?
Esta é uma boa pergunta?
Hi ,
You may be able to fix it yourself.
Here’s a link that will help with this. Select your key and key type
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 556
4 comentários
Is this an internal laptop keyboard or a separate desktop keyboard?
por Ken Grubb
William Waite your computer is a Dell Alienware 15 R3?
por oldturkey03
Duh, I see it now. Have you reached out to Dell to see how much a replacement keyboard is? That helps in computing a repair. It should also get you to install instructions to help you removing the keyboard to look at whether and how you can repair it.
por Ken Grubb
Internal keyboard. Yes, Alienware m15 r3 I believe. I have not contacted Dell. Taking it to a repair shop tomorrow for analysis and estimate.
por William Waite
