Ir para o conteúdo principal
O Xtreme 2 é um alto-falante Bluetooth portátil grande, lançado em janeiro de 2018. Este alto-falante vem com uma classificação IPX7 e até 15 horas de autonomia da bateria. Modelo: PL
What does the red flashing led mean?
The red led is flashing below the red jbl symbol. What does that mean? The speaker will turn off as soon as I turn it on while plugged into the wall.
Thanks for taking the time to look at my question, regards Cameron
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @camthekiwiboy ,
A red blinking LED indicates that the battery is very low and that it needs to be recharged with the power adapter.
If after fully charging the battery, the speaker turns off when operating on the battery only, then there is a problem with the battery and most probably it will need to be replaced.
Here’s a video that may help with this
Esta resposta foi útil?
Pontuação 3
6 comentários:
Awesome thanks alot that video was exactly waht I need ???
por
Hey mate did I screw the battery by always having it on charge? Cheers
por
@camthekiwiboy
Most batteries are meant to be used so keeping them on charge all the time actually does them more harm than good over time.
Also depending on the type of battery i.e. lead acid, NiMH, LiPO Li-Ion etc it varies as to how to maintain the battery charged (especially if not using them) so that it is also not damaged in any way.
The speaker's battery management circuit should take this into account but then it is supposed to be a "portable" speaker i.e. not normally connected to external power source, so the battery is expected to be mostly used for powering the speaker
That is not to say that you flatten the battery every time you use the speaker. Just use it normally and try not to let the battery charge drop to less than 30% before recharging back up to fully charged
por
i get that i may have after 2 years toasted my battery by leaving it on charge the whole time, but i just replaced the battery an still have red light turns of problem. WHERE DO I GO FROM HERE?
por
It doesn’t charge even after a long time, keeps showing red
por
Exibir mais 1 comentário
Adicionar a sua resposta
Cameron stone será eternamente grato(a).
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 25
Últimos 30 dias: 146
Ao todo: 25,740
